The habitacle fan
13 years 3 months before #36092 by manual-mecanica
The habitacle fan published by Manual-Mecanica
The fan has stopped working, until now when it was put to a tremendous noise, but the other day I put it and turned on the box as if it were capped but it does not work, I have tried the fuses and they are fine.
thank you
13 years 3 months before #36125 by manual-mecanica
Manual-Mecanica response on the Re: the habitacle fan
What car is the problem.
13 years 3 months before #36129 by manual-mecanica
is a renault megane II
13 years 3 months before #36186 by manual-mecanica
If towards noise it can be that the fan engine has been gripped but also checks the resistance that goes in the conguonto of ventilation, it may have been burned to the absence of air flow. I hope it helps you greetings.
13 years 3 months before #36365 by manual-mecanica
Solved, the fan engine was stuck and dirty and the fan speed limiter is charged.
What you have to disarm the entire dashboard panel.
Thank you all for answering a greeting.
