Ford Expedition Automatic Box 2007
13 years 3 months before #36066 by manual-mecanica
2007 Ford Expedition Automatic Box published by Manual-Mecanica
Good morning, a 2007 Ford Expedition Automatic Transmission makes speed changes between 4,000 and 4.5000 rpm, is this normal? or what could be happening? Thank you very much for the help.
13 years 3 months before #36067 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Expedition Automatic Box 2007
Possibly your problem is in the governor should be glued or locked if you already did the maintenance of transmission if it does not verify your oil filter for some reason missing oil flow
