Toyota Hilux 1kd engine does not turn on
13 years 3 months before #36042 by manual-mecanica
Toyota Hilux 1KD engine does not turn on Published by Manual-Mecanica
Good I have a problem with a Toyota 1kd Q who does not turn on does not reach the injunctor controller voltage to the incentors, such as trying the injection controller, thank you.
13 years 3 months before #36131 by manual-mecanica
Manual-Mecanica response on the Re: Toyota Hilux 1KD engine does not turn on
What a friend .. Well, I first reviewing if the pressure regulator that goes in the rail that distributes fuel to the injectors is receiving voltage (5V) then verifies if the sensors (crankshaft sensor, cam sensor) have a return (5V) TBM verifies the fuses. In the lid of the fuse box that is next to the battery, look good if the fuse that says EFI is well. If I was burned, the car does not start ... with the help of a diode focus .. verify if signs reach the injectors connectors ... well I hope you can help you in something ...
13 years 3 months before #36139 by manual-mecanica
Good
with scanters check that when you start marking the engine revolutions, if you maracate 250 rpm up, the start sensor is fine,
2- Put a voltimeter in the cable of the cable of the pressure sensor, you open the switch, you must mark 1.0 V, then you start it and look while you start how much the volts rises, they must rise from 1.25 to 1.50 V. To start. If it does not go up, it will not start because the COMPT. It does not give signal to the injectors.
If there are no Voptejes there is a leak in the
injectors
13 years 3 months before #36140 by manual-mecanica
In general there are always 12.80 volts in the ijection line, if there is no voltage, they do not work, rvis the engine lands, another thing and has a spark ??
12 years 6 months before #41352 by manual-mecanica
Manual-Mecanica response on the Toyota Hilux 1KD engine does not turn on
Friend could you solve the problem?
I arrive at my workshop a Hilux Argentina 1KD FTV with the same problem, we change riel, crankshaft, injection pump, IAT coolant, ECU, EDU, turbo controller, and I do not have injection pulses in the injection, the EDU does not arrive battery energy of the integration reliefs since that pin in particular is the fact that the pin We tested they were extracted from another truck the same of the same year and none of the 2 has transponder)
Thank you very much for your comments
