Audi 80 16V 2.0 140CV
13 years 4 months before #35894 by manual-mecanica
Audi 80 16V 2.0 140CV published by Manual-Mecanica
Can someone tell me how to disassemble the radiator?
I miss water and I can't put on cold welding because the fans bother me.
I also need to know how I can open the trunk. They hit me and has got stuck. I have tried to make lever and I can't disassemble the bumper because the fastening screws are inside the trunk.
I've been able to open it for 5 months !!!!!
13 years 3 months before #36160 by manual-mecanica
Manual-Mecanica Answer on the Re: Audi 80 16V 2.0 140CV
Hahaha Pucha Aver xD The Cheke Radiator who has a butterfly thread or something like despiced at the bottom .. If you don't have you will have to take out the hose below to throw the refrigerant (it wears a clamp) Usually an pliers are used to squeeze it and it is released I do not explain myself well. If you can throw it somewhere to recover it ... there is buy it new .. well we continue with the nuts or bolts that hold the body wing radiator looking entry through the back seats .. will they be folded to your model? I don't know .. but if not, something you will have to cut ... if you have folding because look like what is clinging you cut or disarms
greetings ..
