I have a Siena S 2000 and water problems
13 years 4 months before #35884 by manual-mecanica
The water throws me through the reserve bidon to the few blocks but does not lift temperature I have a few days ago and I do not understand much of the subject because I came from old cars. Please if someone can help me would be very useful.
13 years 4 months before #35885 by manual-mecanica
Manual-Mecanica Answer on the Re: I have a Siena S 2000 and water problems
Hi Beto, for what you say you must have the Board blown. Maybe they overheated it, it would have to appear in the recovery vessel traces of oil and in the emulsion engine (oil with water). Greetings
13 years 4 months before #35889 by manual-mecanica
It may be the Curatata Board that would be more serious.
Or the other would be only air in the cooling circuit.
Luck.
13 years 4 months before #35907 by manual-mecanica
Thanks for the answers. Yesterday I cheered and disarmed the thermostat and I was empty. I changed it and improved a lot. He threw some water but it was air in the circuit. Sorry in the heating in progress inside the cabin. Check water and oil and do not seem dirty so I discard the Board for now. What is not like to purge the water because I only found a piricon in the radiator but the heating is higher. I would appreciate help
13 years 4 months before #35942 by manual-mecanica
By putting the refrigerant fluid the alefaccion must be open, so that it does not remain with air.
