Ford Ghia 93 does not turn on
13 years 4 months before #35871 by manual-mecanica
Ford Ghia 93 does not turn on published by Manual-Mecanica
Greetings to all, my problem is that the car does not turn on.
Regularly when turning the ignition switch, a buzz was heard, I imagine that it is the gasoline pump, lately that noise is no longer heard and the car does not turn on; The pump changed it a couple of months ago, I already check fuses and everything is fine, a friend tells me that it can be the relay that energizes the pump, the detail is that I do not know where that relay is located.
If someone could guide me about it, I would appreciate it very much.
13 years 4 months before #35873 by manual-mecanica
Manual-Mecanica response on the Re: Ford Ghia 93 does not turn on
Czech first the inertia switch is on the right side of the Cajela A veses is booted with one blow you just have to oppress the red button from the upper part of the suitch
usually operates in this principle
13 years 4 months before #35875 by manual-mecanica
-The first place what should be heard is the boot engine pusher and then the engine should rotate and try to start. If not and does nothing. Possibly be a battery theme, check it. To check if it is a gas pump failure, you can, with the help of a partner (if the car is gasoline) try to start the car with a lubricant spray (remove the air filter before). Sprinkle lubricant for air intake, while the other partner gives the contact key and turns the engine. If so starts (just while you are throwing the powdered oil). The failure is of the pump. All the best.
