Opel Corsa C Aire
13 years 4 months before #35848 by manual-mecanica
Opel Corsa C Air Published by Manual-Mecanica
The a/a compressor does not work ... gas is fine. Good! .......... Thank you and greetings
13 years 4 months before #35854 by manual-mecanica
Manual-Mecanica Response on the Re: Air Air Corsa C
Disconnect the prisoner and make a bridge between Aybo connects the direct understander to 12 volts to get out of doubt
13 years 4 months before #35868 by manual-mecanica
The compressor connector cable carries two cables ....... One is positive and another negative? ...
