MITSUBISHI MONTERO MOTOR 4M41
12 years 11 months before #35700 by manual-mecanica
MITSUBISHI MONTERO MOTOR 4M41 Published by Manual-Mecanica
Good friends I have a problem with a 4m41 motor mitsubishi that pulls black smoke, but it may not seem that the sky clouds and lost strength when the engine turns on and when starting it and accelerating more black smoke pulls but if I release the accelerator at the minute it takes more force the engine will be that the injectors died or will be just to calibrate them
12 years 11 months before #35703 by manual-mecanica
Manual-Mecanica Answer on the Re: Mitsubishi Montero Motor 4m41
Good friend Your problem is that there is a lot
12 years 11 months before #35704 by manual-mecanica
Friend is diesel and you think that calibrating only the injectors is solved or how could I solve it because the problem suddenly was running and suddenly it was left without strength and began to throw a lot of black smoke
12 years 11 months before #35705 by manual-mecanica
Check the turbo there is the safe problem :)
12 years 8 months before #38108 by manual-mecanica
Manual-Mecanica Answer on the topic Mitsubishi Montero Motor 4m41
Hello, I had that problem with a Mazda 6 and it is that in the multiple of admission it has a venturi for control of revolutions and the bolts of the butterfly valve had broken so it was all the time closed and began a problem exactly the same as yours would recommend that you start there I do not think they are the injectors they do not fail like that one moment from one moment
