Start R19 problem
13 years 4 months before #35901 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Start R19
There a sensor that is responsible for sending the cutting signal of the spark that is the magnet captor no position of position of the crankshaft, in some mono -point vehicles there was a relay that commanded everything but I do not know if it will be your case not in all existed, in Fiat there is a green relay called relay double that will fail.
13 years 4 months before #35925 by manual-mecanica
Wuauuu .............. Another research line ... Thank you look
13 years 4 months before #35943 by manual-mecanica
Well .... The car already looks a new coil (of scrapping) bounces a coil and impulse collector, the latter could not dig due to connections but old full of pore ..... I already want to end this nightmare ...... for me it can k the cause be a supersucio collector .... I hope
13 years 3 months before #35983 by manual-mecanica
Of course, if you always start cleaning before changing anything, I hope you have no lucky problems.
