Low compression
13 years 4 months before #35259 by manual-mecanica
Low compression posted by manual-mecanica
Hello I have a 1994 2000 Renaul Laguna. Taques. Thank you very much for your information.
13 years 4 months before - 13 years 4 months before #35293 by manual-mecanica
Manual-Mecanica response on the Re: low compression
Yes, valves can be regulated.
The valve adjustment is as follows:
1- Admission: 0.20 mm with cold engine.
2- Exhaust: 0.40 mm with cold engine.
The best way to decarbonize the valves is to draw the cylinder head and clean it.
luck
Latest edition: 13 years 4 months before by .
13 years 4 months before #35310 by manual-mecanica
Hello .... Look, first you should see how the valve seats are ... It may be the low compression for loss in said compression for bad closure of the valves, whether seats, guides, the valves themselves ... not just a record of valves will serve you ... as Guillermo tells you, for all this I tell you, you have to remove the cylinder head. Well, surely you have the problem, in the combustion camera.
