How can I adjust the altitude of the lights?
17 years 5 months before #3521 by manual-mecanica
I would like someone to explain to me what is the correct method to adjust the lights of a mitsubichi montero sport '99
17 years 5 months before #3533 by manual-mecanica
Manual-Mecanica response on the Re: How can I adjust the altitude of the lights?
I do not understand your question what you want to adjust the angle or what you have or do not have the team to graduate them .-
17 years 5 months before #3540 by manual-mecanica
The truth is that I do not have the appropriate equipment for that reason is my consultation if there is any homemade method to make said adjustment ... and if what I need to adjust is the angle and the height since when the lights light the light killer are too open and one is higher than the other. Thanks for any contribution that can be offered in advance ...
17 years 5 months before #3541 by manual-mecanica
Hello, I hope this serves you usually I have and use the garage wall I put the car four meters +- of the same and the lus of the low lights it has to give me half the height of the bone headlights of the center of the lighthouse to the floor half the Izq lighthouse, which does not bother so much to the opposite and the right can light the bench a little more. I hope it sieges you and does not complicate you worse ...
17 years 5 months before #3551 by manual-mecanica
Hello, the form is the following the car in a street or a flat site approximately ten meters from the wall. The graduate of the headlight height in the zero position The lights must be approximately at one meter high floor that the most or worth the statistical for the graduation of the Altuta of the lights then there are two screws one for the height and one to graduate the direction of the light you And that alum defcent to the car, try to do it and make me know something, I greet you Alfredo.-
