I have no pulses in the GQ15de engine,
13 years 5 months before #35074 by manual-mecanica
I don't have pulses in the GQ15de engine, published by Manual-Mecanica
Hello colleagues, I have a problem with a Nissan car with an QG15 engine does not turn on and I have already tried all the components and I do not have 12v to the ECU and the truth is the electrical scheme that I have does not match the brain of this car, I ask you some tips to be able to solve it, what more tests should perform to have a spark? Because doing all the tests I already got pulses in the injectors thanks to a pulse tester but I have no spark. Thanks I will wait for your opinions
13 years 5 months before #35078 by manual-mecanica
Manual-Mecanica Answer on the Re: I have no pulses in the GQ15de engine,
Check fuses and matrix fuses in certain ECUs when the uncovers on the card where the pins are marked all Ig1 and 2 etc. I hope it helps you something
13 years 5 months before #35086 by manual-mecanica
What model is it is Japanese or original or national helm
13 years 5 months before #35090 by manual-mecanica
Look my friend the car that year is
if it does not have a spark,
check the ECM reverse,
check
the computer feeds and land then
prove with a logic tip the camshaft sensor if it generates pulses and the crank sensor
all the measures have in the terninals of the ecm
