Mitsubishi Colt GTI does not start
17 years 6 months before #3485 by manual-mecanica
Mitsubishi Colt GTI does not start published by Manual-Mecanica
Hello, I have a problem with my car and I would like to help me if they can. I have a Colt GTI of the Redonditos. It turns out that it does not start and the lights of the painting are not lit, but the windows and the radio and all the things that are activated in the engine when you give it to the contact work well What is the breakdown? The switchboard or alarm, which has a disconnector or something. If they could guide me, I would appreciate it very much. All the best.
17 years 5 months before #3512 by manual-mecanica
Manual-Mecanica Response on the Re: Mitsubishi Colt GTI does not start
First of all, check the fuses that are both inside in the capping of the car, you may have one burned and that is why the lights do not turn on, then this fault went to the improviso or I already came to you, check or disconnect the alarm if you have it but it totally disconnects the cable that blocks you the current of the alarm car you recognized it since they are the thickest cables that you see in the branch you have in the branch. and let me know
