It does not turn on
13 years 2 months before #34832 by manual-mecanica
Does not light published by Manual-Mecanica
I have a problem with Ford Focus 2003 does not turn on only some lines in the tacometer but nothing to turn on
13 years 2 months before #34833 by manual-mecanica
Manual-Mecanica Response on the Re: Do not turn on
First describe that it has passed before the problem was located and the symptoms of the fault to give you a diagnosis
13 years 2 months before #34837 by manual-mecanica
What happens is that I was checking the fan that does not go down and was testing with another relay and as it made short and turned off the engine I may turn on and does not go and the tacometro only puts pure guines
13 years 2 months before #34838 by manual-mecanica
Look in those cases there are 3 things that you can make a memory to fly because it is sent a signal to the ventilation relay and you do not change it any
other ayas voous a fuse eph
another because with the scanner to have to reset it because this when there is a cutting the functions of the memory
the reset does not last more than about 5 min 5 min.
13 years 2 months before #34839 by manual-mecanica
an effi fuse which is
