How to turn off the dashboard oil change in Caliber
13 years 5 months before #34753 by manual-mecanica
Turn the ignition to on with the engine off. DEPRESS THE ACCELERATOR PEDAL THREE Times The Turn Ignition Off. That Should Rest The Oil Minder. Don't Slam The Pedal Three Times Real Fast. Count it out, One, Two, Three.
Source (s):
Certified Chrysler Jeep and Dodge Tech
Ase and Mi Master Certified
Turn the ignition to on Continue with the engine off. Take the accelerator pedal three times and then turn off the ignition. This should restore the Ghange Oil indicator. Do not tighten the pedal three times very fast. Count, one, two, three.
Source (s):
Chrysler Jeep Certificate and Dodge
ASE technology and my Master Certificate
Lucky
13 years 5 months before #34794 by manual-mecanica
Felix good morning, if that is the correct way I would like if you could put it in the section of known mechanical problems so that it is at the hands of other users thank you very much.
13 years 5 months before #34802 by manual-mecanica
Thanks tomorrow I return and put it into practice greetings
