How to turn off the dashboard oil change in Caliber
13 years 1 month before #34713 by manual-mecanica
Good day I would like to know why the dashboard
does not go out after the oil change in a
2009 caliber and continue with oil change, do the right oil
to the viscosity that the manual puts
greetings
13 years 1 month before #34724 by manual-mecanica
I think the only way is with the scanner corresponding to your vehicle, it does not turn it off not because it is another oil if not because you have to warn the ECU that has already been done.
13 years 1 month before #34728 by manual-mecanica
Turn the key up to (ON) with the engine off. Press the thorough accelerator and release slowly. Remember that you must take your time. That is the right way to do it. B)
13 years 1 month before #34750 by manual-mecanica
Thank you, I will make it for the trip and I tell you greetings
13 years 1 month before #34751 by manual-mecanica
I have no scanner anyway thanks
