Derby Mi 2006 Filter
13 years 5 months before #34650 by manual-mecanica
Derby Mi 2006 Filter Published by Manual-Mecanica
Does anyone know where it carries it?, no matter how much I have searched for it, will it find it, will it bring it inside the gas tank?
13 years 5 months before #34662 by manual-mecanica
Manual-Mecanica Response on the Re: Filter Filter Derby Mi 2006
Dear Dakhar. I also have a Derby 1.8 2004 Model Entry, and the gasoline filter is in the back of the rear axle. You need to lift the car to take it out, secure it with lifting towers not with the hydraulic cat. You are going to need flat screaming. Be careful with the connections are plastic and remove by pressing with their hands. I hope it helps you. Greetings
