MY SILVERADO INTEASE PROBLEM2001
13 years 5 months before #34497 by manual-mecanica
problem with the ignition of my Silverado2001 published by Manual-Mecanica
Well I tell you that my silverado from the last Saturday presents the next fault that has me crazy after changing a battery note that the alternator is not keeping the voltimeter needle where I used and the interior light does not turn on when opening the doors and when the suiche does not turn on the looks of the board (ABS, airbag, check Engine) or anything
13 years 5 months before #34499 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the ignition of my Silverado2001
Check the land of chassis and the positive that are not sulfatado
13 years 5 months before #34505 by manual-mecanica
If you have no current in any place the battery is downloaded or the isolated cable, as Czech Fritish says that the terminals make good contact, it is of that battery with bolts in the terminals that go ahead.
13 years 5 months before #34513 by manual-mecanica
No and replace the land cables and battery positive and even bought the battery : Angry:
13 years 5 months before #34524 by manual-mecanica
I remind you that they do not wear anything that land that comes out of the term
