Peugeot 206 HDI air conditioning
13 years 5 months before #34485 by manual-mecanica
PEUGEOT 206 HDI Air Published by Manual-Mecanica
Hello: If you can help me, I have a Peugeot 206 HDI of 2003, when putting the air conditioning it goes well on the part of the driver but by the part of the co -pilot comes at room temperature if I close the driver's grilles still exit the same at room temperature, I have changed the pollen filter, I have disassembled the glove compartment in case I saw in the air block somewhat loose or broken and I do not appreciate anything. I await your thank you
13 years 5 months before #34501 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 206 HDI air conditioning
You have to first verify the precions and if everything is fine, the bad evaporator has
