Velocimetro party98
13 years 5 months before #34416 by manual-mecanica
Velocimetro Party98 Published by Manual-Mecanica
Hello everyone, I just acquired a Ford Fiesta 98 ​​Motor 1.3, the question is that the speedometer does not work and I would like to know if any of you has the repair manual for this model or if you know how the type of speed of the speedometer is verified and in case you change the process to do it, thank you very much in advance and greeting to all the people who use this forum to solve problems or doubts
13 years 5 months before #34420 by manual-mecanica
Manual-Mecanica Response on the Re: Velocimeter Fiesta98
Hello Brother Mira, you have to first check where the Cup of the box is where the tripoids there is located the valve there will be fixed that it carries a gualla and three cables or two verifies that the gualla is good and not started both there and on the board if for this reason it brings cable cable a vertfic nadamas that does not sulfate if this two options you will already have to replace the sensor
