Estimated, thanks for your contribution, the regulation of valves is at 0.25 and 0.30 mm edm and esc respectively ... the cams is the original and is like new ...
the distribution, when I disarmed thought that it was badly done and not mark anything, and as I could not find ulgun cylinder 1 in escape) This causes me doubts, since the brands of the cam did not match ... I tell you that the slowdown is irregular, but at high or when driving it is guning ... the other is that when it turns on cold it costs too much to stabilize and fail, until it is a good time until it reaches a normal t °. With the ignition advance over the 30 ° (advanced) the idle is regularized and with the cold engine it is almost no need to take temperature for the engine to work well ,,, the emptiness in the positive recirculation does not vary ... I think that tomorrow I will verify the position of the camshaft ... I think it can be that ...
thanks for its time, and any contribution will be welcome ...
