Chevrolet Blazer Tahoe Automatic Box
17 years 4 months before #3425 by manual-mecanica
Chevrolet Blazer Tahoe Automatic Box published by Manual-Mecanica
Could you help me and tell me how to change the filter and oil from a Chevrolet Blazer Tahoe 93 automatic box? or if they have any manual? Thank you
17 years 4 months before #3428 by manual-mecanica
Manual-Mecanica Answer on the Re: Automatic Box Chevrolet Blazer Tahoe
You must disassemble the box from the box and when you take it out you should find the oil filter, how many kilometers the car has and that defect makes you recover the oil if you are not burned because you remember that the new oil has more cleaning properties and if you change everything you can sometimes create a problem if the box has enough kilometers traveled.- Greetings Alf
17 years 4 months before #3440 by manual-mecanica
Hello thank you for the answer and the advice had told me that I had to get the carter out of the box I wanted to confirm it I have a mechanical workshop and injection I do not dedicate myself to automatic boxes but the problem is a friend. The truck has 130000 miles and when it is directly starting to skate and does not hook the change does not exceed 90 km told the one that the filter can be covered so I asked me to change it I will keep the oil as you told me thanks again.
17 years 4 months before #3446 by manual-mecanica
Also check the overmarcha cable sometimes they are thrown and can create those problems too, the filter is rectangular if I am not mistaken, you do not want to listen, my father always made a small cup of coffee full of brake league to the change to loosen the stamps of the valve body now do not know if you want to do it.- Greetings Alfred The box discs are already worn.
17 years 4 months before #3514 by manual-mecanica
Hello friend:
First I want to tell you that the oil filter is covered in the exchange box, it produces a noise when walking and you also run out of march because you have no oil flow. I advise you to revise the smell of oil and color if this edion or dark you have disks problems.
But eye if the oil is good that you may have another problem I descend the Blazer's box but I imagine that it is electronically and if it is ACI it may have a problem of a tightness for example the (TPS) the engine acceleration butterfly. As you can also have a problem in the governor's T/AO empty modulator.
