Help with Ford ka possessed .. !!!
13 years 6 months before #34107 by manual-mecanica
Manual-Mecanica response on the Re: Help with Ford ka possessed .. !!!
The coils can be disassembled and you take it to an electric so that with a test bank of the Czech here in Chile they do at least, now the Rocam engine has many temperature problems but nothing of the other world, check lands as the companions tell you well and the most important thing is that checks the theme of the light indicator of reheating because if the warm was very strong, it would the lid where you made the oil and blando the color of the same. Czech sort this because if you do not do the vehicle will always heat and never walk well.
13 years 6 months before #34112 by manual-mecanica
Hi Kikemec, indeed my ka had a very strong reheating, and I never turned on the light. In fact, it has already had several and I find out because smoke comes out ahead of the windshield, but the light that ignites. I think I am going to install a needle temperature clock because surely that valve never worked, because a friend has a ka and tells me that when the temperature begins to rise that light begins to flash, it is turned on only when it is already overheated. I change the oring of that valve already stopped overheating and driving refrigerant, it only has the fault that I describe here, although I have not used it much because I do not know if you can damage something with this failure. You are right, my fear is that the butt is damaged, but my wife tells me that she checked the oil and is normal, but today I am going to look removing the cover that you tell me. Good idea, here the coils also check me in the electric workshops, but today it is the worker's day in Venezuela and everything is closed, so it will be tomorrow. Thank you all, I will inform you when checking everything they tell me .. !!!
13 years 6 months before #34123 by manual-mecanica
Look at these car not everyone links the oil but with everything that read bends camera, it gets it or not oil by reheating the camera I suggest you lower it and brush it
13 years 4 months before #35882 by manual-mecanica
Greetings to all .. !! Thanks to the suggestions I managed to repair my ka, indeed, before going to the workshop I disassembled the coil myself, only four star tip screws, and I found that I had 6 to 7 fissures throughout the waterfall, in different ways. I acquired one and installed it. It was perfect so he is no longer possessed. FRIED FRIEND, I have to check what you tell me since after this it is driving oil through the camera's packaging, so I presume or burned the packaging or folded the camera, or both. Thank you all for the aid .. !!!
13 years 4 months before #35951 by manual-mecanica
As you had told you, this damaged coil signal, high voltage leaks generate that markers jump.
