Help with Ford ka possessed .. !!!
13 years 3 months before #34090 by manual-mecanica
Help with Ford ka possessed .. !!! Posted by manual-mecanica
Buanas friends, I have a curious problem with my wife's vehicle. We have a 2007 Ford Ka with Zetec Ro Cam engine of 8 valves, 1.6 liters, 105,000kms, I think this model with that engine, the same of the Power party, only came to Venezuela, I am not sure. The problem is that a week ago I was driving in full storm, very strong, and the engine began to fail as if the distribution had been wet, they already know, typical failure as a spark plug did not work. Upon arriving at my destination I realized that it was not that, but that the engine was super-recalled, to the point that the water tank cover broke, the entire engine was stained from the refrigerant red. The board of reheating of the board never turned on. Check and I was driving the refrigerant by the temperature valve. The curious thing about the matter is that the car seems possessed now, because being in idle, and accelerated giving a fast footwear to the accelerator (as a boy accelerates in a semaphor to chop with another car) the engine fails equal to the typical failure of a spark plug out of operation, and the needle that marks the minutes of the time of the time, if the clock of the time that is on the board, begins to advance the fault of the engine..!!! It is not a joke, this is totally true ... once I stop accelerating, the engine returns to Relay and the clock works normally. The fault is also presented when driving, intermittently, I see that the clock needle a few minutes while the fault is presented ... Once the engine stops failing, the clock stops anticipating. They tell me that with the overheating maybe a clock cable is short and produces the engine failure, but I don't know if this is possible. They also tell me that possibly a spark plug has departed and does not work well, but I could not take out the spark plugs because I have no idea how to get the cables, since they seem fixed to some tubes that cover the spark plug and I do not want to pull them, I do not go to be that it damages them. I know that this clock has a red bombing that indicates something about an engine sensor that deactivates it if the electronic key is not placed in the suichera, I do not know if this has to do with that engine sensor and that is why it fails, but friends, I do not know what to do to the ka to correct the problem. Thanks to who can help me
13 years 3 months before #34092 by manual-mecanica
Manual-Mecanica response on the Re: Help with Ford ka possessed .. !!!
Urgent check the earth cables possibly any and see if the one who goes to the body is connected and clean or non-sulfatado, check the cable that is attached to the mass always of mass that should go on the side of the change.-
13 years 3 months before #34097 by manual-mecanica
Very close to what the partner recommends the same thing after an overheated began that same fault and my problem was solved in the connectors of the injunctors, for the heat and the time of use, the insulator was broken to the cable and with only moving them I notic
13 years 3 months before #34103 by manual-mecanica
I have had three Ford Focus with the same problem in the workshop and the failure is produced by ignition when it has a high voltage leak the fault similar to that of a spark plug and the high voltage circulates as parasitic currents that go crazy the markers if the problem is a bad polarization but it is a defect of design. board.
13 years 3 months before #34105 by manual-mecanica
Thanks short circuit, touches 1 and choto for your suggestions. Uff, I see that I will have to review several things. I will then review the mass cables in the first place. I imagine that there is no way to check if that ignition coil has a leak, but only replace it with a new one or is there any way to know? Now touches 1, did you have to replace the cables of the injectors or just placed insulating (plastic teipe or something) on ​​the cable? Today I was checking those cables by the way but I didn't notice anything strange. I will review again tomorrow because if you notice that the cart is 5 years old and the corrugated shirts that protect the cables are already toasted by the heat and are being released. Thanks friends for this valuable help .. !!!
