Fiat Stilo 1.6 16V 103CV Dinamic
13 years 6 months before #34044 by manual-mecanica
Fiat Stilo 1.6 16V 103CV Dinamic Published by Manual-Mecanica
I wave everyone I just bought a Fiat Stilo 1.6 16V 103CV Dinamic from 2003 and my problem is today I will get up I will start it and when I put the key the ram puts me at 0:00 and a lot of error messages begins to leave: Airbag fault, Averia Seguri. Floy connection vehicle. And by completely turning the key to start, it does as if it did not have a battery and the electricity is leaving and the picture has kilometers a few strange noises x please if someone could help me or tell me something that helped me to repair the error
. Thanks beforehand
13 years 6 months before #34045 by manual-mecanica
Manual-Mecanica Answer on the Re: Fiat Stilo 1.6 16V 103CV Dinamic
Hello friend, it is a typice fault of lack of tension in the battery, Medila with a multimeter, it has to have 12.25 volts as minimal and if not load it or change it if it does not respond, greetings.
13 years 6 months before - 13 years 6 months before #34046 by manual-mecanica
Thank you for your help, tomorrow I check the battery and I tell you. I think that will be because I don't think K is from the switchboard, which would be much worse. greetings
Latest edition: 13 years 6 months before by .
13 years 6 months before #34060 by manual-mecanica
Good Jal I have given him a bottle to start it and started but now I get a motor fault message together with the light lightweight witness. I no longer do, your k advises me. Thanks in advance Salu2.
13 years 6 months before #34083 by manual-mecanica
Well now if I advise you to scan to have an idea of ​​the failure that is marking the warning light, greetings. :)
