Escort time set 2000
13 years 6 months before #33967 by manual-mecanica
Manual-Mecanica Response on the Re: Escort Time 2000 time
Well, in the case of the canal of the escape side, already being on time the engine should turn without the whole tree, well at least one degrees? This is normal to turn. I must clarify that the screw is well adjusted.
13 years 6 months before #33968 by manual-mecanica
Well, in the case of the canal of the escape side, already being on time the engine should turn without the whole tree, well at least one degrees? This is normal to turn? I must clarify that the screw is well adjusted.
13 years 6 months before #33969 by manual-mecanica
As the companions disagree with you to put the time it is true, but if you do not want So how these figures are going to see the trees, only put the arrand rule and forget about points and others, ... if I do not explain to me I can send you some diagrams that I can get out of the alldata program, greetings
13 years 6 months before #33971 by manual-mecanica
Look for the correct tightening of the tree bolt because the catarina should not move, anywhere, it should be firm if there is any displacement then you have any damage to the tree or in the catarina
13 years 6 months before #33984 by manual-mecanica
Align trees on horizontal grooves, cran
