Piston 1 and 3 do not work 3.2 isuzu rodeo95
13 years 3 months before #33900 by manual-mecanica
Piston 1 and 3 do not work 3.2 Isuzu Rodeo95 Published by Manual-Mecanica
They could help me with a 3.2 engine from Isuzu Rodeo does not work the piston 1 and 3 already check the synchronization and keep failing
13 years 3 months before #33904 by manual-mecanica
Manual-Mecanica Response on the Re: Piston 1 and 3
Did you take the compression to the cylinders?
Did you check if there is spark in the spark plugs and if the signal reaches the injectors?
If you did all this, you changed spark plugs and tried coils can be valve problem that is with problems in the cylinder head
13 years 3 months before #33909 by manual-mecanica
Hello haros? He did some work to the cylinder head; (I rectify valve seats? I agree with JONI07, the first is mechanical elements of the engine if there is a good compression ...+-125-140PSI or more continue with ignition system ... (the coil and integral module when they fail to cancel all the cylinders) then if it is fine verify the circuits of the injectors verify signal in the injectors with a injector test lamp. Verify injectors ... but it is unusual for two at the same time ... Of course I make the clarification that it is a Chevrolet vehicle it is better to use the diagnostic strategy and follow your steps you find in the service manual ...
13 years 3 months before #33914 by manual-mecanica
Thank you and check spark and the injectors I need the compression of the cylinders, change the coils and followed the same
13 years 3 months before #33937 by manual-mecanica
As the companions say, you must check the compression of the cylinders, if it is very low or null you will have two opsions or rings or valves, to know which of these two factors are a simple test, put some oil in the combustion camera and measures the compression again if it increases considerably it is rings problems, if it remains the same then it is a problem of valve It is tested to regulate before. luck
