Hyundai Elantra 2000/ Problem Tank Gasoline
17 years 6 months before #3385 by manual-mecanica
Hyundai Elantra 2000/ Problem Gasoline Tank Published by Manual-Mecanica
Greetings, about a month ago I am having problems with my Hyundai Elantra 2000. It takes time to fill the gasoline tank, I start filling it and the gasiline comes out as if the tank was full, I have to wait for an average of 5 minutes to lower or accommodate gasoline to continue and if I pishop the pisteist to continue drowning and gasoline comes out. No type of filtration or smell of gasoline or any type of jalon or speed loss is observed.:(
Thanks for your help
17 years 6 months before #3404 by manual-mecanica
Manual-Mecanica Response on the Re: Hyundai Elantra 2000/ Problem Gasoline Tank
You would have to check the tank filling tube there is a pressure disagree tube possibly is obstructed or there is something inside that prevents gasoline from flowing properly, check it when it is level of level thus you avoid losing too much gasoline when it is clear.
17 years 6 months before #3414 by manual-mecanica
Thanks a thousand for the aid, today Wednesday takes it in the morning to the workshop and the caniter effect and one of the relief bomb are damaged, thanks for everything and success.
Danessairis;)
17 years 6 months before #3415 by manual-mecanica
Danessairis;)
17 years 6 months before #3430 by manual-mecanica
Ask for the old spare parts because I stop a bit strange about the canister for your security, ask them like this, you are sure what they changed to you
