Accompanying Airbac
13 years 6 months before #33938 by manual-mecanica
Manual-Mecanica Response on the Re: Airbac accompanying
Friend the chairs cannot go ahead, that as the first thing, but if you want it is to cancel it, disarm from the glove compute and disconnect the connector from the bag nothing more, so then you can install it again, but I insist that it is not a good idea to disconnect the Airbac or put a chair forward, luck brief
13 years 6 months before #33963 by manual-mecanica
Well if you disconnect the airbag releasing the connector, cancel the function of it but you run the risk of leaving the entire system inactive, in addition to the fact that you will immediately give you error code, think it well because it can be harmed.
13 years 6 months before #34086 by manual-mecanica
They tell me that I can baffle it and put a resistance from 3 onmios
13 years 6 months before #34095 by manual-mecanica
Enter with the scanner to the airbag module, read the active data and see what resistance it has, based on this place ... although I am not sure that it works ..!
