Renault Megane 2004 does not start
17 years 6 months before #3374 by manual-mecanica
Renault Megane 2004 does not start published by Manual-Mecanica
Hello friends, I have a problem with a megane:
I give Marha and do how it starts, but no. At times there is a spark and gasoline, but
couldn't they help me?
17 years 6 months before #3375 by manual-mecanica
Manual-Mecanica response on the Renault Megane 2004 theme does not start
The key recognizes it, see if there is any laziness cable can also be the crankshaft sensor that calls the plane send the signal and lose it, check the spark plugs
17 years 4 months before #4056 by manual-mecanica
The solution to go more oriented is to put a diagnostic machine and already tells you where the failure comes and take off to go around.
ALL THE BEST
