Trooper distributor
13 years 6 months before #33696 by manual-mecanica
Trooper distributor published by Manual-Mecanica
Hello friends .... I turn to you again .... As you remember I have an isuzu trooper 2.6 this was losing oil for the distributor .... something that took it out to change the orring that I had bad and my problem is that now the distributor does not want to enter the distributor I lack as 1Centimeter ...... What will be tested everything so that it will be in good ... attentive to your advice and comments ........... thank you very much ....
13 years 6 months before #33741 by manual-mecanica
Manual-Mecanica Answer on the Re: Trooper Distributor
I think he put a thicker or ring
