Chevy does not start
13 years 2 months before #33625 by manual-mecanica
Chevy does not start published by Manual-Mecanica
How about friends of the forum I require of his urgent help for a 2001 Chevy Monza, 5 Vel Manual. Mot. 1.6 MPFI, it turns out that my wife was driving and suddenly I listened to a noise in the engine and turned off several attempt to start the engine and nothing went to see what the problem was, it turns out that the distribution band was exit from the tensioning pulley and the screw of the crankshaft pulley was loose and that caused the band to also get out of the pulley and that the car went out, according to what I Press the pulley screw and install the band and I wanted to start and start but do not keep the rpm and if accelerate does not respond and immediately goes out, we had to leave the car in a gas station, hope (that nothing happens), as I can put it in time or what will be the failure, it really urges me, in advance I thank you.
13 years 2 months before #33628 by manual-mecanica
Manual-Mecanica Response on the Re: Chevy theme does not start
Good day Friend X What you comment I suggest that I check if it is in point if it is in point should be the piñon guide of Sigual like that and the one of the cam
13 years 2 months before #33636 by manual-mecanica
It seems to me that you only need to put good on time, but look very well that the crap dam of the crankshaft is spoiled the channel that goes in the crankshaft because these vehicles tend to do it, anyway it seems to me that it is not very cause that double valves that engine if I do not remember.
13 years 2 months before #33640 by manual-mecanica
Thanks Kikemec for your help, some guide to put it on time or how and where I can have that information, good day.
13 years 2 months before #33641 by manual-mecanica
Good day, according to this when he launched it, the car advanced a good distance but of 40 k/h. It did not happen and then the rest, I do not think that any valve has been bent and no explosion is heard, how can I put it on time? thank you.
