Ford party air problems
13 years 4 months before #33585 by manual-mecanica
Ford party air problems published by Manual-Mecanica
Good I have a 2002 Ford Fiesta The problem is the next year ago the car when I stopped in the tails the car stopped cooling to air but did not cool when he ran it was that he cooled and at nights I cool up only when he ran it a week ago the orijinal partner was the maintenance of all the pipes, the condenser was linked to the evaporator. But still with the fault the car in the queues does not cool only when I run it or when it rains is that the car cools good that it can be
13 years 4 months before #33588 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with the air of Ford Fiesta
Hi Felix Your problem This is in electroVental because the answer is the following when the air is contained, you should turn on the electrventilator in a low speed since these car working with two speeds or does not arrive signal from the high -prsutatic valve or the reflex is damaged or the resistance this bad has to check whether when the air is contained in the air. The precions enclose clear when wheel enters enough and lowers the precions there begins to cool
13 years 4 months before #33589 by manual-mecanica
Greetings Felix, your problem is a bit weird since the holidays are a fridge, hehe, performs this test, in the parking lot lights the car and 10min later lights the air conditioning at an average speed, if after ten minutes but it does not cool as it is check or do maintenance the main electrventilator and if it has a second also check it, check the collector or the base of the electro and the same blade if it does not Or you change, another thing you can try and if there is space is to place a universal electrventilator of 8 "(assuming that you only have the radiator) in the front of the condenser, I had a similar problem in the truck and solve it by placing an electro of 12", just like you with a new compressor. You comment how it went. Greetings.
13 years 4 months before #33602 by manual-mecanica
Friend to Ecender The air sees the Elecro tanbien but if and noticed that when throwing water to the radiator the car cools well will have to do with the electro but it is Nuebo Valeo
13 years 4 months before #33629 by manual-mecanica
Ok but it is on I went to the low speed because if it is on it verifies that it does not have much gas if you have a manometro verifies that x low is 40 yx high 200 to 230 that are the two thing that fault that fault that the electro does not work or have a lot of gas but it has a lot How it works
