Problems with a kia picanto
13 years 6 months before #33566 by manual-mecanica
Problems with a Kia Picanto published by Manual-Mecanica
Saluidos,
I have a problem with a kia picanto (Morning) RPM of idle are not stable, sometimes they rise to 4000 rpm, in the scanner I have these codes (p0123 sensor Sensor Pedal Accelerator Pedal A/Butterfly A - High input signal; P1505 Adaptation Control Air
Relations
13 years 6 months before #33567 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Kia Picanto
Hello, I think it does not regulate the release PQ will have some aspirated air -type sensor or by pass in poor condition also the scanner tells you something about that?
13 years 6 months before #33568 by manual-mecanica
Nooo only that comes out in the SCAner, and change the ISC valve and continue the fault .... !!! : Ohmy:
13 years 6 months before #33570 by manual-mecanica
Hello, for all that the scanner tells you, the first thing you should be to erase all the failures of failures and try.
If your scanner can make any measurement of the accelerator pedal potentiometer check it continuous.
Another possibility of pecanic failure as air intake.
All the best
13 years 6 months before #33571 by manual-mecanica
Ok, thank you very much, I'm going to check that ......
