Winsdtar 2001 Transmission
13 years 6 months before #33548 by manual-mecanica
Winsdtar 2001 Transmission Published by Manual-Mecanica
I need help with a winsdtar that suddenly walking the trnasion was neutralized and turned it off and I prayed again but nothing does not give either back or in front already check the oil and it is fine does not smell burnt nor do you see remains of anything I need guidance to know where to know how to check thank you
13 years 6 months before #33685 by manual-mecanica
Manual-Mecanica Response on the Re: Winsdtar Transmission 2001
Look if you have fault codes TCM can do that when there is a fault but you may have problems with the converter
13 years 6 months before #33691 by manual-mecanica
Hello, what are you like, the safest thing is that a satellite has already swept between the drum and the setelite. It is necessary to disarm it all and has an approx cost of 6,500 pesos.
13 years 6 months before #33692 by manual-mecanica
I do not give me any code for what I disconnected the battery for a while and no longer came out any code or the Chek Engine is not turned on,
