Corsa 2002 Hatch Back electrical problems
13 years 4 months before #33545 by manual-mecanica
ELECTRICAL PROBLEMS CORSA 2002 HATCH BACK Published by Manual-Mecanica
Good morning,
I have electrical problems with my Corsa 2002 Hatch Back, the problem is as follows:
The car turns normally, but after a few moments the instruments (tachometer and other needles, indicators of light from the board) are turned off) and does not serve the electric direction in the steering wheel (it becomes harder than a mechanical direction). The car does not go out and works normally, alternately the problem is restored and it happens continuously.
I don't know what it can be, I hope you can help me.
13 years 4 months before #33549 by manual-mecanica
Manual-Mecanica Answer on the Re: Electrical Problems CRESS 2002 Hatch Back
So you counted it seemed a false contact .. Look that the drums of the battery are clean you can sand a little and squeeze well .. Then confirm that the car has the masses of chassis, engine, etc. In the fusera it checks all the fuses, rel and not finding false contacts .. I hope it serves something luck
13 years 4 months before #33550 by manual-mecanica
I have already checked the fuses, all and in the same way I have cleaned the drunks but still the problem persists, I do not know if a false in the wiring could cause that!
13 years 4 months before #33551 by manual-mecanica
You will have to check the entire install, the most difficult in some installs is to determine if the file does not make false contacts when connected .. you turn crazy
13 years 3 months before #33750 by manual-mecanica
AMMM for the symptoms that I think is a module that is the one that controls the address and lighting .. Aki himself .. You can download a workshop manual: Corsa Hatchback, Corsa Cy there come the locations of the modules and for that they serve ....
I hope and serve you something ...
