Diesel engine
13 years 6 months before #33544 by manual-mecanica
Diesel engine posted by manual-mecanica
Estimated:
I need to know if it is true that a diesel engine (Nissan) that has difficulty starting in the morning (during the day impeccable) is because it is with the molten engine (without compression) is true or is a myth.
Thank you very much
greetings Eugenio
13 years 6 months before #33546 by manual-mecanica
Manual-Mecanica Response on the Re: Diesel Motor
Hi Eugenio, assuming that the battery is in good condition and the starter engine also the first thing you should do is check the heating spark plugs for ER that does not have any burned, comments that you discover, greetings.
13 years 6 months before #33576 by manual-mecanica
Dear jal
If the Filters battery already replaced, check the burners are all well, the engine after starting impeccable, no loss of performance is noticed (strength).
It is true that the tired engine (low compression) does not start, others tell me that that does not alter the ignition.
Greetings and thanks for the attention Eugenio
13 years 6 months before #33580 by manual-mecanica
Hello friend, it is true that a Nissan Dieselcon low compression delay at cold start but after this works perfectly now if you want to do a test to check it, take out the heating spark plugs, and have a little oil in the camera to each cylinder to increase the compression and you will see that it starts quickly although it will smoke for a while until it burns the oil. On sea level it will not start you for anything because it is worse in height. luck
13 years 6 months before #33590 by manual-mecanica
Dear; Thanks for the information, are the test, but information if possible, what are the values ​​of the minimum and maximum compression in a Nissan Diesel 1.7 engine ???
Greetings Eugenio
