Distribution strap
13 years 6 months before #33465 by manual-mecanica
Distribution Correa published by Manual-Mecanica
Hello people I am new here and I need to ask for help to change the distribution strap I have an Inca Seat just like Volkwagen's caddy is 1.9 diesel and it is a 2000 model
if there manuals or where to download them I thank you because here I do not find or do not look good
good for now thank you very much greetings
13 years 6 months before #33472 by manual-mecanica
Manual-Mecanica Response on the Re: Distribution belt
Friend I recommend that you take it to a specialized place ... because if you look bad at best it would be out of time and you would have to lower it and accommodate it, and in the worst case a tooth could skip and damage some valves and camera and everything that follows that ... in any way luck and greetings ...
13 years 6 months before #33495 by manual-mecanica
First of all, welcome to MDM, see if you are going to change it by maintenance you do not need manuals you have the brands yourself in the belt and on the pulleys to not have problems if it is by cut I look in the data to see if it is and post the photo.
13 years 6 months before #33506 by manual-mecanica
Friend I think the question is to help me not to recommend a mechanic
anyway thanks I am not adventurous for that I ask
13 years 6 months before #33507 by manual-mecanica
Thanks Kike I hope you can help me, I know that I have to be careful with the bomb that does not get out of point
I hope you can give me an idea of ​​how the pulleys are marked very much
