Light marches back
17 years 5 months before #3602 by manual-mecanica
Manual-Mecanica Answer on the Re: Light march back
The most sensible thing is that you take it to an electrical revision, it could be the casode that is disconnected or damaged by the electronic valve of the setback or reverse, she only sends the signal to the computer to access the recoil light, if it has failures simply does not turn on the light. I hope I have helped you. GREETINGS
