Light marches back
17 years 6 months before #3344 by manual-mecanica
Light marches back published by Manual-Mecanica
Hi, I have a 2007 Pointer, take it to service to the agency and after a few days the alrma was to fail, but not of the hub when the doors have already corrected that clean the connectors of the relayers probe everything and work well now the uz of march to after it does not work and if it funeate well, anylebator would have failed? If we can help me what I already do check the fuses and the spotlights are fine
17 years 6 months before #3345 by manual-mecanica
Manual-Mecanica Answer on the Re: Light march back
Check the interruptting that is in the change or on the velocity lever may have been disconnected
17 years 6 months before #3369 by manual-mecanica
Thanks for your attention but apologize my ignorance where I locate the change since on the lever I find nothing
17 years 6 months before #3376 by manual-mecanica
The speed box or checks the fuses in the speed box must have a switch with some cables Go go to the backlight or if you do not check a connector that must be on the driver's side on the side where you support the feet that are coming the cables go go to the rear lights check if it reaches the cable that goes to the rear stop
17 years 5 months before #3574 by manual-mecanica
It may be some cable that is touching in a sheet
