Hydraulic pump
13 years 4 months before #33338 by manual-mecanica
Hydraulic bomb published by Manual-Mecanica
:( Hello forum people, I have a problem with the hydraulic bomb of my Accent Gls, I change the ruleman because towards a lot of noise and now the bomb does not have enough precion, the direction is also very hard. Someone would give me a hand? To know what can be .... Thank you
13 years 4 months before #33347 by manual-mecanica
Manual-Mecanica response on the re: hydraulic pump
You will not have armed the scanning plate to the revex and instead of generating this neutral one ???
13 years 4 months before #33356 by manual-mecanica
Hi Charly. I tell you lap thequeta that I think you tell me it has only one way of assembling because it has a mold, the rest is in any way has no sides, so it catches my attention a lot
13 years 4 months before - 13 years 4 months before #33361 by manual-mecanica
I do not know if we are talking about the same thing, I mean the album that contains the scanning plates, in general those that I have disarmed, the plate or steering wheel is possible to invest it and do not press, so the idea, then do not have much to analyze.
unless sweeping plates do not work free inside the disc and do not drag the oil to the circuit.
Latest edition: 13 years 4 months before by .
13 years 4 months before #33381 by manual-mecanica
Hi Charly, if we are talking about the same platelet, but have one more test and take the engine to 7500 rpm in a curve and when the address will make up the address began to affirm again, the truth is I am baffled, unless the valve that carries at the exit of the pump has been struck and upon receiving precion it takes off, it is very possible. Of course I thank you for your collaboration friend, in the same way we will be in Contacaco for other consultation a hug
