Ford Lobo 2004 Water Filtration
13 years 8 months before #33175 by manual-mecanica
Water leak in a 2004 Ford Lobo. Posted by manual-mecanica
In a 2004 Ford Lobo there is a water filtration that has soaked the mat on the co -pilot side, I do not find the origin of the escape except how to avoid it. Thank you.
13 years 8 months before #33178 by manual-mecanica
Manual-mechanics response on the topic Re: Water leak Ford Lobo 2004
If you have AC, check your condensate drain line from the heat exchanger
13 years 8 months before #33213 by manual-mecanica
From what you say you have broken the heating radiator it is common that when it fails the liquid passes to the avitaculo
