Can it be that two valves are burned?
13 years 2 months before #33118 by manual-mecanica
Can it be that two valves are burned? Posted by manual-mecanica
My car is an R 11/94 the other day when I wanted to pass it from gasoline to gas, he made an counterclosion off a lot of white smoke, to which I first react was to turn it off. Then he did not start until the distributor a little, Andubo a few days and failed again, they told me that it was the distributor, I changed it regulates it and remains the same, for the escape it shows that the air sucks, if you put a cloth or a bag it is spilled and brings it back ... and they do not react 2 pistons .. :(
13 years 2 months before #33127 by manual-mecanica
Manual-Mecanica response on the Re: Can it be that two valves are burned?
If you can change with the hot engine, you may have twis
13 years 2 months before #33164 by manual-mecanica
Spark they have the 4 spark plugs, and that baffles me.
13 years 2 months before #33172 by manual-mecanica
Well you have no choice but to lift the cylinder head and see the other one is before lifting it, you take a compression to get out of doubt that it is not an air filtration in the admission I think there are no more turns than to give it
13 years 2 months before #33212 by manual-mecanica
First of all it measures the compression to save that we are looking, if there is not or is very low they can be folded or the pistons may have been damaged.
