ABS failure indicator.
13 years 3 months before #33061 by manual-mecanica
ABS failure indicator. Posted by manual-mecanica
Hello! The light of the control box has lit with the ABS indicator. I have behaved that it works correctly. How can I deactivate that light from the control picture so annoying?
thank you. all the best
13 years 3 months before #33065 by manual-mecanica
Manual-Mecanica response on the Re: ABS failure indicator.
Sorry, you could tell me what car you have
13 years 3 months before #33081 by manual-mecanica
Hello, if forgiven that I had forgotten to indicate brand and model.
It is a Mercedes Vito V230 TD.
13 years 3 months before #33083 by manual-mecanica
Mercedes Vito V230td. Thanks and greetings.
13 years 3 months before #33084 by manual-mecanica
Hello if your problem is the discomfort of light on light you only have to remove the corresponding fuse and check that it does not affect other uses and I personally recommend that you repair it because when something fails it is for something and it is better to prevent.
All the best
