Remove Motsubishi Furgon L-300 1987
13 years 8 months before #33037 by manual-mecanica
Fellow mechanics, I might have to remove the engine from a 1987 Mitsubishi L-300 van. I've never worked on vans before and I'd like to know if there are any recommendations for removing the engine, as the workspace is usually quite limited. What would be the easiest way to remove the engine?
Greetings,
I'm from Santiago, Chile. I do on-site maintenance and I'm happy to help the community with anything I know.
Waldo.
13 years 8 months before #33040 by manual-mecanica
Manual-mechanics ' response on the topic Re: Removing the engine from a 1987 Mitsubishi L-300 van
Dear Sir,
I removed an engine from that vehicle, and the best way is from underneath.
You should place it on a platform with a slight incline so you can remove it more easily, or
you can lower it into a pit. Remember that you have to remove the transmission, or it will never
come out. I hope this
helps. Regards
13 years 8 months before #33071 by manual-mecanica
Thanks companion was the information I needed ...
