Check for Toyota
13 years 4 months before #32926 by manual-mecanica
Consult by Toyota published by Manual-Mecanica
Hi, I'm new here.
My consultation is, I have a Toyota Yaris year 2007 and has the problem that costs you to start.
Thanks in advance.
13 years 4 months before #32994 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation by Toyota
Compa, is what you raise, any detail ??? You took him to the scanner to see if he throws any code ??? Greetings
13 years 4 months before #32999 by manual-mecanica
Hello, query at what time it is difficult to start in cold or it is at all times, apart if it is cold the engine pulls when it starts, when it was the last one you see that you relaxed an injector cleaning, change of fuel filter (if it tubed it), spark plugs, since it could be a battery in poor condition, alarm if you have installed, etc. You could put more data.
13 years 4 months before #33005 by manual-mecanica
If I have made it scan and I do not deliver any code, I have also changed spark plugs, benzine filter, injector cleaning, the battery also changed it. When it is cold, it costs you to start, then one stops it and starts it instantly and starts normal. But if one travels and stops him for more than 20 minutes he has a hard time starting
13 years 4 months before #33006 by manual-mecanica
Dear technical consultation
in Readi Shit the engine or remains normal both hot and cold
