MEGANE 1.9DCI problems
13 years 7 months before #32868 by manual-mecanica
MEGANE 1.9DCI problems posted by Manual-Mecanica
First I greet Tdo the world and K is the prima time I connect.
Well the problem is bought a 2002 1.9 dci renault megane, and the owner told me the turbo, total k bought a turbo and mount it, but then I throw a lot of white smoke and almost even binds, and does not upload the revolutions. Then I have cam ... the injectors, I have proven the pressure of the pump and the same .... I don't know if someone can give me any idea but I would do very well.
Greetings and thanks in advance.
13 years 7 months before #32888 by manual-mecanica
Manual-Mecanica Answer on the Re: Megane 1.9DCI problems
Hello SVB2008,
the white smoke is due to low temperature in one or more cylinders, this in turn is produced by water pass to some cylinder, fissure in a piston or shirt, the advisable thing is to lower cylinder head, perform hydrostatic test, examine packaging. It is likely water pass. Luck.
Miguel
13 years 7 months before #32908 by manual-mecanica
Most likely, your engine is bass of compression when putting a new turbo you inf up a lot and for the discharges of gases that return to the admission is passing oil because of that the white smoke, be careful that the oil inside the cylinder can react as fuel causing the engine to shoot in turns
13 years 7 months before #32957 by manual-mecanica
Good, thanks for everything, the issue is that I have no compressimeter, so since I could not plug the diagnosis machine, I have stayed with a mechanic for the plug but not yet to be able to ... then if it is not of any sensor and it is of compression k advise me I put new rings and semi -semicinetes of the bench and what or what?
By the way I repeat thanks for the help!
