AVEO Distribution Correa
13 years 8 months before #32846 by manual-mecanica
AVEO Distribution Correa published by Manual-Mecanica
Good, I would like to know how the distribution strap of a Chevrolet Aveo is changed from now on : D
13 years 8 months before #32848 by manual-mecanica
Manual-Mecanica Response on the Re: Aveo Distribution Correa
Is it the same as the Daewoo Kalos? What engine and year does your car have?
13 years 8 months before #32876 by manual-mecanica
and the same as the cloud 1.6. It is the same engine, you have to dismantle the straps of elements, take out the Damper, the motor tip support to work comfortable, take out the plastic covers and enter the strap, you put the engine in the upper dead point taking the pulleys to their marks, they are very clear so you will see Brands, you release the tensioner and change the boil the tensioner bearing is a little comlpicado of wearing nesicitas another person who helps you, luck
13 years 8 months before #32954 by manual-mecanica
The procedure is similar in almost all Chevrolet with distribution strap. I leave you a reference image for the correct alignment of crankshaft and camshaft pulleys, which is ultimately the most delicate detail of this repair. It corresponds to the E-Tec II 16V engine
13 years 8 months before #32966 by manual-mecanica
The only difference is the tensioner, this band is tense turning the antifreeze bomb, it is the only point other than the other Chevrolet
