Remove Suzuki Maruti half
13 years 7 months before #32708 by manual-mecanica
Remove Suzuki Maruti semi- published by Manual-Mecanica
Greetings to all.
I cannot get the semi -axis (internal homocinetic) side of the gearbox in a Suzuki Maruti year 2001, I understand that it is similar to Suzuki Hatch.
I do not know how to do it if only pulling the axis (which already intent) or carries some insurance, it is because I had to take the box because the third march does not enter.
Thank you.
13 years 7 months before #32721 by manual-mecanica
Manual-Mecanica Answer on the Rezuki Maruti semi-axes
You just have to pull it very strongly or you can also make a lever with a very long flat scroller.
If it carries insurance as the other cars but that insurance is the one that makes it not easy, so you have to make lever.
13 years 7 months before #32728 by manual-mecanica
Thank you very much Othoniel for responding to my consultation, I will do what you tell me, there is no problem that makes something break something: Dry: , there is some side that you have to get first or do not matter?
Have a good day.
13 years 7 months before #32729 by manual-mecanica
It doesn't matter what side you first.
There are some semi -messages that have been working without disarming for the time and they give more work to get them out
but with strength and skill if they leave
you will do lever supporting you from the box so I recommend protecting the box.
Oh you prepare a container for when the semi -the semi -out will spill oil (that's normal)
13 years 7 months before #32829 by manual-mecanica
Perfect I made lever, much was not necessary and both sides, oil or spill, since I had previously removed the oil from the box. Since the 3 march does not enter, at first glance there is a fork with a lot of game that must be changed. Another question How really knowing when a synchronizer is bad?
Thank you. Greetings from Chilean Patagonia
