Problems with Montana 97, Code P1870 A
13 years 7 months before #32692 by manual-mecanica
Problems with Montana 97, Code P1870 A Published by Manual-Mecanica
I have a problem with this code, I do not want to disassemble the transmission that they advise me, I would appreciate them very much
13 years 7 months before #32706 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Montana 97, Code P1870 A
The problem is the valve body
replace it (together with the solenoids)
13 years 7 months before #32773 by manual-mecanica
Hello grace for the advice, what the box does is that it feels that the change enters but the engine does not rest, by axis. On road the Tacometro is in 3000 rpm at 60 miles P HR, while before that same speed, the tacometer marked 2200 rpm, I just repaired the engine but now it makes this fault, they replaced pistons, ring, oil pump, rod metals, their respective packaging, rectified head Code that marks is P1870. You only think that it is the body of valves the transmission is a 4T60E. I would appreciate your comments
13 years 7 months before #32802 by manual-mecanica
That fault code in that vehicle and with that same transmission is GM newsletter.
But if you doubt that you are working correctly and without alterations in your signal the CKP as well as the wiring that goes to the transmission reviewing sensors and electrovalves
13 years 7 months before #32813 by manual-mecanica
Thanks for the information, it is appreciated
